Ana içeriğe geç
Asus X200MA Motherboard Replacement
Neye ihtiyacın var
  1. Asus X200MA Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: adım 2, 1 resimden 1.
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: adım 4, 1 resimden 1.
  5. Asus X200MA Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: adım 6, 1 resimden 1.
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: adım 8, 1 resimden 1.
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: adım 9, 1 resimden 1.
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: adım 10, 2 resimden 1. Asus X200MA Motherboard Replacement: adım 10, 2 resimden 2.
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: adım 11, 2 resimden 1. Asus X200MA Motherboard Replacement: adım 11, 2 resimden 2.
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: adım 13, 2 resimden 1. Asus X200MA Motherboard Replacement: adım 13, 2 resimden 2.
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: adım 14, 3 resimden 1. Asus X200MA Motherboard Replacement: adım 14, 3 resimden 2. Asus X200MA Motherboard Replacement: adım 14, 3 resimden 3.
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alli Krininger
391 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S2G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,239
