Ana içeriğe geç
Asus X200MA Screen Replacement
Neye ihtiyacın var
  1. Asus X200MA Screen Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Screen Replacement: adım 2, 1 resimden 1.
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Screen Replacement: adım 3, 1 resimden 1.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Screen Replacement, Battery: adım 4, 1 resimden 1.
  5. Asus X200MA Screen Replacement: adım 5, 1 resimden 1.
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Screen Replacement: adım 6, 1 resimden 1.
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Screen Replacement: adım 7, 1 resimden 1.
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Screen Replacement: adım 8, 1 resimden 1.
    • Slide the battery up and out.
  9. Asus X200MA Screen Replacement, Screen: adım 9, 1 resimden 1.
    • Remove the following four 3 mm screws using the Phillips #0 screwdriver.
  10. Asus X200MA Screen Replacement: adım 10, 2 resimden 1. Asus X200MA Screen Replacement: adım 10, 2 resimden 2.
    • Lift and separate the screen from the base plate.
  11. Asus X200MA Screen Replacement: adım 11, 2 resimden 1. Asus X200MA Screen Replacement: adım 11, 2 resimden 2.
    • Insert the metal spudger into the side of the screen casing. Work the spudger around the perimeter of the casing in a rowing motion in order to release the plastic clips holding the casing together.
    • Place a finger in the space between the casing while undoing the clips to keep the casing from re-closing.
  12. Asus X200MA Screen Replacement: adım 12, 1 resimden 1.
    • Lift the half of the casing with the screen away from the other half of the casing and place the screen half on a work space by itself.
  13. Asus X200MA Screen Replacement: adım 13, 1 resimden 1.
    • Remove the following six 3 mm screws using the Phillips #0 screwdriver.
  14. Asus X200MA Screen Replacement: adım 14, 3 resimden 1. Asus X200MA Screen Replacement: adım 14, 3 resimden 2. Asus X200MA Screen Replacement: adım 14, 3 resimden 3.
    • Use the jimmy tool to peel the following stickers from the screen:
    • The silver sticker near the bottom.
    • The information sticker near the top.
  15. Asus X200MA Screen Replacement: adım 15, 3 resimden 1. Asus X200MA Screen Replacement: adım 15, 3 resimden 2. Asus X200MA Screen Replacement: adım 15, 3 resimden 3.
    • Lift the latch holding the component in place.
    • Remove the component by pulling in the direction of the arrows.
  16. Asus X200MA Screen Replacement: adım 16, 2 resimden 1. Asus X200MA Screen Replacement: adım 16, 2 resimden 2.
    • Lift the screen from the casing and place the two next to one another.
Sonuç
Alli Krininger
391 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S2G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 796
