Ana içeriğe geç
Asus X200MA Trackpad Replacement
Neye ihtiyacın var
  1. Asus X200MA Trackpad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: adım 2, 1 resimden 1.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Trackpad Replacement, Trackpad: adım 3, 2 resimden 1. Asus X200MA Trackpad Replacement, Trackpad: adım 3, 2 resimden 2.
    • Use the spudger to lift up and remove the black plastic covering.
  4. Asus X200MA Trackpad Replacement: adım 4, 1 resimden 1.
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  5. Asus X200MA Trackpad Replacement, Mouse: adım 5, 1 resimden 1.
    • Remove wider blue strip with tweezers.
  6. Asus X200MA Trackpad Replacement: adım 6, 1 resimden 1.
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  7. Asus X200MA Trackpad Replacement: adım 7, 1 resimden 1.
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: adım 8, 2 resimden 1. Asus X200MA Trackpad Replacement: adım 8, 2 resimden 2.
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vanessa Garcia
1.763 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G24
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,093
