Ana içeriğe geç
Asus X202E-UH31T Battery Replacement
Neye ihtiyacın var
  1. Asus X202E-UH31T Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
  2. Asus X202E-UH31T Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
  3. Asus X202E-UH31T Battery Replacement: adım 3, 1 resimden 1.
    • Once the back is off the device, unscrew the 7 1.2mm phillips head screws that hold the battery in place using a small phillips head screw driver
  4. Asus X202E-UH31T Battery Replacement: adım 4, 1 resimden 1.
    • Once the screws holding the battery are out, use the plastic opening tool to disconnect the battery cable ribbon from the motherboard
  5. Asus X202E-UH31T Battery Replacement: adım 5, 1 resimden 1.
    • After replacing the battery, attach the wire ribbon to the motherboard and screw the designated screws back into the battery to secure it
Sonuç
To reassemble your device, follow these steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,427
