Giriş
In this guide you can learn how to replace the headphone jack on your laptop.
Neye ihtiyacın var
Remove the 9 1.2mm phillips head screws on the bottom of the computer using the smaller Phillips head screw driver.
Once the back is off the device, unscrew the 7 1.2 mm phillips head screws that hold the battery in place. Use the smallest (#0) phillips head screw driver
Once the screws holding the battery are out, use the plastic opening tool to disconnect the battery cable ribbon from the motherboard
