Ana içeriğe geç
Asus X401A Processor Replacement
Neye ihtiyacın var
  1. Asus X401A Processor Replacement, Processor: adım 1, 2 resimden 1. Asus X401A Processor Replacement, Processor: adım 1, 2 resimden 2.
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: adım 2, 3 resimden 1. Asus X401A Processor Replacement: adım 2, 3 resimden 2. Asus X401A Processor Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: adım 3, 3 resimden 1. Asus X401A Processor Replacement: adım 3, 3 resimden 2. Asus X401A Processor Replacement: adım 3, 3 resimden 3.
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: adım 4, 3 resimden 1. Asus X401A Processor Replacement: adım 4, 3 resimden 2. Asus X401A Processor Replacement: adım 4, 3 resimden 3.
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: adım 5, 1 resimden 1.
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: adım 6, 1 resimden 1.
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: adım 7, 2 resimden 1. Asus X401A Processor Replacement: adım 7, 2 resimden 2.
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: adım 8, 1 resimden 1.
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: adım 9, 3 resimden 1. Asus X401A Processor Replacement: adım 9, 3 resimden 2. Asus X401A Processor Replacement: adım 9, 3 resimden 3.
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: adım 10, 2 resimden 1. Asus X401A Processor Replacement: adım 10, 2 resimden 2.
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: adım 11, 2 resimden 1. Asus X401A Processor Replacement: adım 11, 2 resimden 2.
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: adım 12, 3 resimden 1. Asus X401A Processor Replacement: adım 12, 3 resimden 2. Asus X401A Processor Replacement: adım 12, 3 resimden 3.
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Stiles
152 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G4
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 2,191
