Ana içeriğe geç
Asus X501A-RH31 Keyboard Replacement
Neye ihtiyacın var
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over so that the back is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Asus X501A-RH31 Keyboard  Replacement: adım 2, 1 resimden 1.
    • To unlock the left tab, make sure the tab on the left has red showing.
    FixBot'a Sor
    Yorum Ekle
  3. Asus X501A-RH31 Keyboard  Replacement: adım 3, 2 resimden 1. Asus X501A-RH31 Keyboard  Replacement: adım 3, 2 resimden 2.
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
    FixBot'a Sor
    Yorum Ekle
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 1. Asus X501A-RH31 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 2.
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
    FixBot'a Sor
    Yorum Ekle
  5. Asus X501A-RH31 Keyboard  Replacement: adım 5, 1 resimden 1.
    • Turn the laptop over and open the top so the keyboard is facing you.
    FixBot'a Sor
    Yorum Ekle
  6. Asus X501A-RH31 Keyboard  Replacement: adım 6, 2 resimden 1. Asus X501A-RH31 Keyboard  Replacement: adım 6, 2 resimden 2.
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
    FixBot'a Sor
    Yorum Ekle
  7. Asus X501A-RH31 Keyboard  Replacement: adım 7, 1 resimden 1.
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Asus X501A-RH31 Keyboard  Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Romana Hruby
596 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 1,552
