Ana içeriğe geç
Asus X501A-RH31 Motherboard Replacement
Neye ihtiyacın var
  1. Asus X501A-RH31 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Motherboard Replacement: adım 2, 1 resimden 1.
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Motherboard Replacement: adım 3, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 3, 2 resimden 2.
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Motherboard Replacement, Keyboard: adım 4, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Motherboard Replacement: adım 5, 1 resimden 1.
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Motherboard Replacement: adım 6, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 6, 2 resimden 2.
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Motherboard Replacement: adım 7, 1 resimden 1.
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Motherboard Replacement, Fan: adım 9, 1 resimden 1.
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Motherboard Replacement: adım 10, 1 resimden 1.
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Motherboard Replacement: adım 11, 3 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 11, 3 resimden 2. Asus X501A-RH31 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 Motherboard Replacement: adım 13, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 13, 2 resimden 2.
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 Motherboard Replacement: adım 14, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 Motherboard Replacement: adım 15, 1 resimden 1.
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 Motherboard Replacement: adım 16, 3 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 16, 3 resimden 2. Asus X501A-RH31 Motherboard Replacement: adım 16, 3 resimden 3.
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 Motherboard Replacement: adım 17, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 17, 2 resimden 2.
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 Motherboard Replacement: adım 18, 2 resimden 1. Asus X501A-RH31 Motherboard Replacement: adım 18, 2 resimden 2.
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Romana Hruby
587 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 1,151
