Giriş
This guide will demonstrate how to replace the touch pad in the Asus X501A-RH31 laptop. Please note, the touch pad is a sensitive piece of the laptop, execute caution when taking out the touch pad.
Neye ihtiyacın var
Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
Flip the keyboard over so the side without the keys is facing you.
Using the Phillips #00 screwdriver, unscrew the three screws.
Bir başkası bu kılavuzu tamamladı.
