Ana içeriğe geç
Asus X502C-RB01 Keyboard Panel Removal
Neye ihtiyacın var
  1. Asus X502C-RB01 Keyboard Panel Removal, Keyboard Panel: adım 1, 1 resimden 1.
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Keyboard Panel Removal: adım 2, 1 resimden 1.
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Keyboard Panel Removal: adım 3, 2 resimden 1. Asus X502C-RB01 Keyboard Panel Removal: adım 3, 2 resimden 2.
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Keyboard Panel Removal: adım 4, 2 resimden 1. Asus X502C-RB01 Keyboard Panel Removal: adım 4, 2 resimden 2.
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Keyboard Panel Removal: adım 5, 1 resimden 1.
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jaspal Chauhan
491 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-5, Rodger Winter 2017 UC Davis, Team 1-5, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 871
