Giriş
The keyboard, track pad, and palm rest are all part of the same assembly, if you need to replace any one of these items you will need to replace the whole assembly. This guide will show you how to do that.
Neye ihtiyacın var
While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
