Ana içeriğe geç
Asus X540S notebook PC Hard drive Replacement
Neye ihtiyacın var
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: adım 2, 1 resimden 1.
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: adım 3, 3 resimden 1. Asus X540S notebook PC Hard drive  Replacement: adım 3, 3 resimden 2. Asus X540S notebook PC Hard drive  Replacement: adım 3, 3 resimden 3.
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
    When removing both cables there is a small black plastic flap covering the connection.
    GENTLY lift that flap and GENTLY lift the end of the cable/ribbon and you're good to go.
    My first try I was under the impression it was more of a plug and didn't see any specifics just like above “remove cable” but no description of how.
    Even though I did it wrong, it didn't damage anything, and this guide was a big help.
    F S - Yanıt
    Added a note. Thanks for the comment!
    Padraic Hoselton -
    While lifting the lid, it's useful to have a spudger to detach the snaps from the top
    Emily Klassen - Yanıt
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: adım 4, 2 resimden 1. Asus X540S notebook PC Hard drive  Replacement, Hard drive: adım 4, 2 resimden 2.
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: adım 5, 2 resimden 1. Asus X540S notebook PC Hard drive  Replacement: adım 5, 2 resimden 2.
    • Remove the four Philips #1 screws.
    Wanted to add:
    Must open dvd drawer first to pull up on top housing
    Can only spudge after pulling up on top above DVD opening - stiff expired credit card works good
    No hidden screws, the ones on the bottom are it
    Only 2 ribbon cables, keyboard and touchpad
    Ribbon cables are short, keeping plastic clamps secured on them tricky when reassembling
    Very helpful guide, thank you :)
    Avery Freeman - Yanıt
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Padraic Hoselton
4.180 İtibar
12 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
7 Yorum
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - Yanıt
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - Yanıt
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - Yanıt
No problem!
I will add a note to the keyboard and trackpad on step 2
Padraic Hoselton -
@paperboypaddy what hard drive did you use and what brand? Mine just bit the dust.
Erica O - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 58
Her zaman: 13,862
