Giriş
This guide will show you how to remove the keyboard panel for the Asus X450S.
Neye ihtiyacın var
Open the Optical Drive to allow removal of keyboard before powering down computer.
Lift the side of the top.
Remove the keyboard cable.
Remove the trackpad cable.
When removing both cables there is a small black plastic flap covering the connection.
GENTLY lift that flap and GENTLY lift the end of the cable/ribbon and you're good to go.
My first try I was under the impression it was more of a plug and didn't see any specifics just like above “remove cable” but no description of how.
Even though I did it wrong, it didn't damage anything, and this guide was a big help.
Added a note. Thanks for the comment!
While lifting the lid, it's useful to have a spudger to detach the snaps from the top
13 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
