Ana içeriğe geç
Asus X550ZA-SA100603E RAM Replacement
Neye ihtiyacın var
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them.
    • Seven 14 mm screws
    • Three 4 mm screws
    • Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: adım 2, 1 resimden 1.
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: adım 3, 1 resimden 1.
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
    • The flathead driver has the potential to damage the device. Be careful when handling it.
    • Do not be alarmed if you hear a click as you pry open. These sounds are the clips detaching from the casing.
  4. Asus X550ZA-SA100603E RAM Replacement: adım 4, 2 resimden 1. Asus X550ZA-SA100603E RAM Replacement: adım 4, 2 resimden 2.
    • The motherboard is the big board on the left-hand side of the internals. Remove all 15 bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: adım 5, 2 resimden 1. Asus X550ZA-SA100603E RAM Replacement: adım 5, 2 resimden 2.
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: adım 6, 1 resimden 1.
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot.
    • You will hear a clicking noise once it is pushed in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul Flynn
16 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S5G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 419
