Ana içeriğe geç
Asus X550ZA-SA100603E USB Port Replacement
Neye ihtiyacın var
  1. Asus X550ZA-SA100603E USB Port Replacement, Keyboard: adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E USB Port Replacement: adım 2, 3 resimden 1. Asus X550ZA-SA100603E USB Port Replacement: adım 2, 3 resimden 2. Asus X550ZA-SA100603E USB Port Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E USB Port Replacement: adım 3, 3 resimden 1. Asus X550ZA-SA100603E USB Port Replacement: adım 3, 3 resimden 2. Asus X550ZA-SA100603E USB Port Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E USB Port Replacement: adım 4, 3 resimden 1. Asus X550ZA-SA100603E USB Port Replacement: adım 4, 3 resimden 2. Asus X550ZA-SA100603E USB Port Replacement: adım 4, 3 resimden 3.
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E USB Port Replacement: adım 5, 1 resimden 1.
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E USB Port Replacement, USB Port: adım 6, 3 resimden 1. Asus X550ZA-SA100603E USB Port Replacement, USB Port: adım 6, 3 resimden 2. Asus X550ZA-SA100603E USB Port Replacement, USB Port: adım 6, 3 resimden 3.
    Satın Al
    • Using precision tweezers, flip up the retaining flap on the ZIF connector securing the USB port ribbon cable.
    • Gently remove the ribbon cable from the ZIF connector.
  7. Asus X550ZA-SA100603E USB Port Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 4mm screws holding the port in.
  8. Asus X550ZA-SA100603E USB Port Replacement: adım 8, 1 resimden 1.
    • Remove the port from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hi Tim, great step by step instructions to remove the usb port(s). I have a asus notebook MODEL X551MA with dual usb ports that are loose causing my mouse to intermittently lose connection. Ithink the fix is to replace them. I am waiting for a charger port to be delivered since that is barely connecting at all.
Do you have a source i can purchase the dual Usb board for my laptop.
Thank you for any help you can give me in advance.
My Best
Mike OBrien
Mike OBrien - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 3,098
