Giriş
This tutorial demonstrates how to remove the motherboard from your laptop. Doing so allows you to upgrade the CPU, implement a higher quality graphics card, and improve the operating power of your computer.
Neye ihtiyacın var
Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
Gently lift the keyboard to access the three ribbon cables connected to the motherboard
Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
Gently pull the ribbon cables from their sockets on the motherboard.
Use a Phillips #0 screwdriver to remove the thirteen black 4 mm screws from the face of the motherboard.
Use a Phillips #0 head screwdiver to remove the four silver 4 mm screws from the face of the motherboard
Use a Phillips #0 head screwdriver to remove the one black 4 mm screw from the indented area above the fan.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Hello, I am interested in know how could I change the diode m51j, due to the volts from the USB don't function it, please could you help me, my email address is ing.gabriel.alcazar@gmail.com if you have the technical manual will be great
Thank you
