Ana içeriğe geç
Asus X5511M-RCLN03 Battery Replacement
Neye ihtiyacın var
  1. Asus X5511M-RCLN03 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Battery Replacement: adım 2, 1 resimden 1.
    • Remove all 4 mm screws using a #00 Philip's screwdriver.
  3. Asus X5511M-RCLN03 Battery Replacement: adım 3, 1 resimden 1.
    • Open the laptop with the keyboard facing upward.
  4. Asus X5511M-RCLN03 Battery Replacement: adım 4, 1 resimden 1.
    • Carefully pry up the keyboard cover with your fingers or with a plastic spudger.
  5. Asus X5511M-RCLN03 Battery Replacement: adım 5, 2 resimden 1. Asus X5511M-RCLN03 Battery Replacement: adım 5, 2 resimden 2.
    • Remove electrical ribbons by gently lifting up the tab that is holding them down, then pulling them gently.
  6. Asus X5511M-RCLN03 Battery Replacement: adım 6, 1 resimden 1.
    • Set the keyboard plate aside. Gently lift up battery to remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ryann Easterbrook
154 İtibar
1 Kılavuz yazıldı
3 Yorum
Peer review:
Step 1: This step is unclear and seems unnecessary. It should be removed or reworded to be more specific: "Position the laptop with the back cover facing upward."
Step 3: This step is also unclear and seems unnecessary. It should be removed or reworded: "Re-position the laptop with the back cover facing downward."
Step 5: This step is grammatically confusing and should be reworded. Example: "Lift up the tab covering the electrical ribbons. Pull the ribbons gently to remove them."
Courtney Clark - Yanıt
Steps 5 and 6 are missing photos so the instruction is not clear.
This was a easy and strait forward repair it took longer to find the tools than to do the repair. The hardest part for me was plugging the flex cables back in as I have a tremor in my hands. the repair took about 10 minutes.
DANIEL HATHAWAY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,615
