Ana içeriğe geç
Asus X551CA CMOS Battery Replacement
Neye ihtiyacın var
    1. Asus X551CA CMOS Battery Replacement, Keyboard Plate Cover: adım 1, 1 resimden 1.
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 2, 1 resimden 1.
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA CMOS Battery Replacement: adım 3, 1 resimden 1.
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA CMOS Battery Replacement: adım 4, 3 resimden 1. Asus X551CA CMOS Battery Replacement: adım 4, 3 resimden 2. Asus X551CA CMOS Battery Replacement: adım 4, 3 resimden 3.
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA CMOS Battery Replacement: adım 5, 1 resimden 1.
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, Hard Drive: adım 6, 1 resimden 1.
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 7, 1 resimden 1.
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA CMOS Battery Replacement: adım 8, 1 resimden 1.
      • Once it is free, remove the hard drive from its internal cavity.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, Spacer: adım 9, 1 resimden 1.
      • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 10, 1 resimden 1.
      • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, WiFi Card: adım 11, 1 resimden 1.
      • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 12, 1 resimden 1.
      • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA CMOS Battery Replacement: adım 13, 1 resimden 1.
      • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, Battery: adım 14, 1 resimden 1.
      • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, Motherboard: adım 15, 1 resimden 1.
      • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 16, 2 resimden 1. Asus X551CA CMOS Battery Replacement: adım 16, 2 resimden 2.
      • Now, locate the two wires connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA CMOS Battery Replacement: adım 17, 2 resimden 1. Asus X551CA CMOS Battery Replacement: adım 17, 2 resimden 2.
      • Remove the wires by easily pulling them parallel to the motherboard's surface.
      • The wires are very fragile. Be sure to pull carefully so that they do not break!
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA CMOS Battery Replacement: adım 18, 2 resimden 1. Asus X551CA CMOS Battery Replacement: adım 18, 2 resimden 2.
      • Remove the LCD display connection by gently pulling on the attached wire.
      • Gently lift any tape that may be holding the connection.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA CMOS Battery Replacement: adım 19, 1 resimden 1.
      • Remove the motherboard from the case by gently lifting it upward.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA CMOS Battery Replacement, CMOS Battery: adım 20, 1 resimden 1.
      • Flip over the motherboard and locate the CMOS battery.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA CMOS Battery Replacement: adım 21, 1 resimden 1.
      • Use the plastic opening tool to pry the battery out of its plastic casing in the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA CMOS Battery Replacement: adım 22, 1 resimden 1.
      • Lastly, lift and remove the CMOS battery from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
Josh
2.970 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G22
5 Üyeler
15 adet Kılavuz yazıldı
6Kılavuz Yorumları
What is the correct battery to use? Where can I purchase it?
Mark Thompson - Yanıt Paylaş
the battery is a cr2032. Its one of the most common battery sizes available just about anywhere from a grocery store to amazon.
Josh - Yanıt Paylaş
does replacing this battery improve battery life?
proa_michael - Yanıt Paylaş
Hello, my Asus x550za suddenly shut off and will not boot. No power, no lights. I've verified 19 volts coming through the AC adapter, power jack and power jack port. I noticed that one side of the CMOS battery holder came unsoldered from the motherboard and is hanging. Could this have caused the laptop to suddenly turn off and to not be able to boot?
Thanks.
Elijah Laub - Yanıt Paylaş
I have a f541s laptop…it has a cmos battery problem but when i open the laptop i can't seem to find the battery on the motherboard,is it possible that it's a built in?
Vutomi Keith nkuna - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 87
Her zaman: 58,645
