Ana içeriğe geç
Asus X551CA Fan Replacement
Neye ihtiyacın var
  1. Asus X551CA Fan Replacement, Keyboard Plate Cover: adım 1, 1 resimden 1.
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Fan Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Fan Replacement: adım 3, 1 resimden 1.
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Fan Replacement: adım 4, 3 resimden 1. Asus X551CA Fan Replacement: adım 4, 3 resimden 2. Asus X551CA Fan Replacement: adım 4, 3 resimden 3.
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Fan Replacement: adım 5, 1 resimden 1.
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Fan Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Fan Replacement: adım 7, 1 resimden 1.
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Fan Replacement: adım 8, 1 resimden 1.
    • Once it is free, remove the hard drive from its internal cavity.
  9. Asus X551CA Fan Replacement, Spacer: adım 9, 1 resimden 1.
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  10. Asus X551CA Fan Replacement: adım 10, 1 resimden 1.
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  11. Asus X551CA Fan Replacement, WiFi Card: adım 11, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  12. Asus X551CA Fan Replacement: adım 12, 1 resimden 1.
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  13. Asus X551CA Fan Replacement: adım 13, 1 resimden 1.
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  14. Asus X551CA Fan Replacement, Battery: adım 14, 1 resimden 1.
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  15. Asus X551CA Fan Replacement, Motherboard: adım 15, 1 resimden 1.
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  16. Asus X551CA Fan Replacement: adım 16, 2 resimden 1. Asus X551CA Fan Replacement: adım 16, 2 resimden 2.
    • Now, locate the two wires connected to the motherboard.
  17. Asus X551CA Fan Replacement: adım 17, 2 resimden 1. Asus X551CA Fan Replacement: adım 17, 2 resimden 2.
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
  18. Asus X551CA Fan Replacement: adım 18, 2 resimden 1. Asus X551CA Fan Replacement: adım 18, 2 resimden 2.
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
  19. Asus X551CA Fan Replacement: adım 19, 1 resimden 1.
    • Remove the motherboard from the case by gently lifting it upward.
  20. Asus X551CA Fan Replacement, Fan: adım 20, 1 resimden 1.
    • Once the mother board is removed, locate the fan.
  21. Asus X551CA Fan Replacement: adım 21, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
  22. Asus X551CA Fan Replacement: adım 22, 1 resimden 1.
    • Lift the fan out of the laptop.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Josh
2.970 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G22
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 5,920
