Ana içeriğe geç
Asus X551CA Hard Drive Replacement
Neye ihtiyacın var
    1. Asus X551CA Hard Drive Replacement, Keyboard Plate Cover: adım 1, 1 resimden 1.
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA Hard Drive Replacement: adım 2, 1 resimden 1.
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA Hard Drive Replacement: adım 3, 1 resimden 1.
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA Hard Drive Replacement: adım 4, 3 resimden 1. Asus X551CA Hard Drive Replacement: adım 4, 3 resimden 2. Asus X551CA Hard Drive Replacement: adım 4, 3 resimden 3.
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA Hard Drive Replacement: adım 5, 1 resimden 1.
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA Hard Drive Replacement: adım 7, 1 resimden 1.
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA Hard Drive Replacement: adım 8, 1 resimden 1.
      • Once it is free, remove the hard drive from its internal cavity.
      FixBot'a Sor
      Yorum Ekle
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
Brandon
2.838 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G22
5 Üyeler
50 adet Kılavuz yazıldı
8Kılavuz Yorumları
You mixed up the red and green screws, sizes are wrong.
The red screws are 9.5 not 14.3!
the yellow screws are 4.3 (mixed up with 14.3 ?) not 9.5 !
You do NOT need to remove the ribbons, just use a small screwdriver.
Tony - Yanıt Paylaş
Excellent work !
Drew Lawrence - Yanıt Paylaş
Same issue as Tony on 09/03/2014
The screw sizings are mixed up. The red screws are 9.5, not 14.3
The yellow screws are 14.3 not 9.5. Please fix the repair guide text
Mevlan Coma - Yanıt Paylaş
It should be fixed now! Thanks to both of you for the tip. By the way, you can always edit the text yourself. ;)
Jeff Suovanen - Yanıt Paylaş
Thanks for the info!
Abe Aleman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 69
Her zaman: 68,003
