Ana içeriğe geç
Asus X551CA Keyboard Plate Cover Replacement
Neye ihtiyacın var
  1. Asus X551CA Keyboard Plate Cover Replacement, Keyboard Plate Cover: adım 1, 1 resimden 1.
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    screw assignments are definitely wrong. I swapped the red and the green, as per comment above, and kept the blue as-is.
    jasonbuechler - Yanıt
    jason is right
    starwilson - Yanıt
    correct, swap the green and red
    Josh - Yanıt
    Jason is correct
    Clem Lanoe - Yanıt
    Thanks everyone. It does seem like someone got their screws mixed up when they wrote this guide. I’ve made some changes as you all suggested, so the screw placements should be more accurate now. If anyone with this laptop could verify the screw measurements with a digital caliper, that’d also be very helpful.
    Jeff Suovanen - Yanıt
  2. Asus X551CA Keyboard Plate Cover Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Keyboard Plate Cover Replacement: adım 3, 1 resimden 1.
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Keyboard Plate Cover Replacement: adım 4, 3 resimden 1. Asus X551CA Keyboard Plate Cover Replacement: adım 4, 3 resimden 2. Asus X551CA Keyboard Plate Cover Replacement: adım 4, 3 resimden 3.
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Don't remove the ribbons, just move the keyboard slightly forward to remove the old battery and insert the new one (just make sure they are all connected when you put it back)
    Flyer292 - Yanıt
  5. Asus X551CA Keyboard Plate Cover Replacement: adım 5, 1 resimden 1.
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Is painting your nails crucial for step 5?
    wiedzmin - Yanıt
    Yes and you have to put lotion on
    joemidjette - Yanıt
    Now, that is a stupid question! Of course! As I am working on 551M, I naturally have to have nails painted orange, with blue accents!
    gregtokarski -
    that boy ain't right
    Rich Spillman - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Josh
2.958 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G22
5 Üyeler
15 adet Kılavuz yazıldı
2 Yorum
WARNING the screw lengths in step 1 are wrong. I tried installing the wrong screws and now my touch pad us ruine
Joe Allen - Yanıt
The screw info has been updated. I’m still not sure if it’s 100% correct, so be sure to keep your screws organized and put each one back where it came from to avoid damage.
Jeff Suovanen -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 5,024
