Ana içeriğe geç
Asus X551CA LCD Replacement
Neye ihtiyacın var
    1. Asus X551CA LCD Replacement, Keyboard Plate Cover: adım 1, 1 resimden 1.
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 2, 1 resimden 1.
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 3, 1 resimden 1.
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA LCD Replacement: adım 4, 3 resimden 1. Asus X551CA LCD Replacement: adım 4, 3 resimden 2. Asus X551CA LCD Replacement: adım 4, 3 resimden 3.
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA LCD Replacement: adım 5, 1 resimden 1.
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, Hard Drive: adım 6, 1 resimden 1.
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 7, 1 resimden 1.
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 8, 1 resimden 1.
      • Once it is free, remove the hard drive from its internal cavity.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, Spacer: adım 9, 1 resimden 1.
      • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 10, 1 resimden 1.
      • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, WiFi Card: adım 11, 1 resimden 1.
      • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 12, 1 resimden 1.
      • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 13, 1 resimden 1.
      • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, Battery: adım 14, 1 resimden 1.
      • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, Motherboard: adım 15, 1 resimden 1.
      • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 16, 2 resimden 1. Asus X551CA LCD Replacement: adım 16, 2 resimden 2.
      • Now, locate the two wires connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 17, 2 resimden 1. Asus X551CA LCD Replacement: adım 17, 2 resimden 2.
      • Remove the wires by easily pulling them parallel to the motherboard's surface.
      • The wires are very fragile. Be sure to pull carefully so that they do not break!
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA LCD Replacement: adım 18, 2 resimden 1. Asus X551CA LCD Replacement: adım 18, 2 resimden 2.
      • Remove the LCD display connection by gently pulling on the attached wire.
      • Gently lift any tape that may be holding the connection.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA LCD Replacement: adım 19, 1 resimden 1.
      • Remove the motherboard from the case by gently lifting it upward.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, Front Display Bezel: adım 20, 1 resimden 1.
      • Locate both of the hinges that connect the monitor to the bottom plate cover.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 21, 2 resimden 1. Asus X551CA LCD Replacement: adım 21, 2 resimden 2.
      • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 22, 1 resimden 1.
      • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA LCD Replacement: adım 23, 1 resimden 1.
      • Locate the two stickers that cover up the screws that hold the front bezel in place
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA LCD Replacement: adım 24, 2 resimden 1. Asus X551CA LCD Replacement: adım 24, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to remove these stickers.
      • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
      FixBot'a Sor
      Yorum Ekle
    6. Asus X551CA LCD Replacement: adım 25, 1 resimden 1.
      • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
      FixBot'a Sor
      Yorum Ekle
    7. Asus X551CA LCD Replacement: adım 26, 1 resimden 1.
      • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
      FixBot'a Sor
      Yorum Ekle
    8. Asus X551CA LCD Replacement: adım 27, 2 resimden 1. Asus X551CA LCD Replacement: adım 27, 2 resimden 2.
      • Once the screws are taken out, the front bezel is ready to be removed.
      • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
      • Gently use hands if necessary to separate the front bezel from the back.
      FixBot'a Sor
      Yorum Ekle
    9. Asus X551CA LCD Replacement: adım 28, 1 resimden 1.
      • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
      FixBot'a Sor
      Yorum Ekle
    1. Asus X551CA LCD Replacement, LCD: adım 29, 1 resimden 1.
      • Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
      FixBot'a Sor
      Yorum Ekle
    2. Asus X551CA LCD Replacement: adım 30, 2 resimden 1. Asus X551CA LCD Replacement: adım 30, 2 resimden 2.
      • Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
      FixBot'a Sor
      Yorum Ekle
    3. Asus X551CA LCD Replacement: adım 31, 1 resimden 1.
      • Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
      FixBot'a Sor
      Yorum Ekle
    4. Asus X551CA LCD Replacement: adım 32, 1 resimden 1.
      • Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
      FixBot'a Sor
      Yorum Ekle
    5. Asus X551CA LCD Replacement: adım 33, 1 resimden 1.
      • Once flipped over, locate the ribbon that is connected to the back of the LCD.
      FixBot'a Sor
      Yorum Ekle
    6. Asus X551CA LCD Replacement: adım 34, 2 resimden 1. Asus X551CA LCD Replacement: adım 34, 2 resimden 2.
      • Gently tug on the ribbon to remove it from the LCD.
      FixBot'a Sor
      Yorum Ekle
    7. Asus X551CA LCD Replacement: adım 35, 1 resimden 1.
      • Now that the ribbon has been detached from the back, carefully remove the LCD.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Josh
2.970 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G22
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
Res Q Service - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 11,370
