Ana içeriğe geç
Asus X555LA-SI305041 CD Drive Replacement
Neye ihtiyacın var
  1. Asus X555LA-SI305041 CD Drive Replacement, Keyboard Assembly: adım 1, 1 resimden 1.
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 CD Drive Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 CD Drive Replacement: adım 3, 1 resimden 1.
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 CD Drive Replacement: adım 4, 1 resimden 1.
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 CD Drive Replacement: adım 5, 1 resimden 1.
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 CD Drive Replacement, CD Drive: adım 6, 1 resimden 1.
    • Using a #0 Phillips screw driver, remove the (5mm) black screw to the left of the CD Drive and to the right of the cooling fan.
  7. Asus X555LA-SI305041 CD Drive Replacement: adım 7, 1 resimden 1.
    • CD Drive should easily slide out.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 7,918
