Giriş
If your computer is starting to slow down, freeze frequently, or display the blue screen of death then your hard drive may be failing. If your hard drive hasn't completely crashed yet then be sure to backup your precious data BEFORE replacing your hard drive.
Neye ihtiyacın var
Remove the following Phillips #0 screws from the lower case:
Six 9 mm screws
Four 11 mm screws
Release the ribbon cables using the plastic opening tool to flip the gray tab on the white connector.
Gently slide ribbon cable out while gray tab is flipped up.
If glued, go ahead and peel ribbon from hard drive.
33 farklı kişi bu kılavuzu tamamladı.
14 Yorum
hi. i have the same laptop. the laptop bsod on me after i used it for a good 6 months. suddenly, when i start the laptop, it always boots me to the bios, the hard drive is change because i thought it is the problem (i just followed the solutions online which is a lot regarding the issue). my suspection is the hard drive connector to the motherboard pcb. is there any way i can replace with or where can i buy replacements for this same part? please help i really need the laptop for my school needs, and sorry for the bad english
I had the same problem. Sorry but its also too expensive to repair and the repair doesnt solve problem %100
AYG -
Im having the same issue. My HDD fails to start when my hand is over the hdd connector (just slight pressure). Any solutions?
ieg -
This is caused by the connection socket on the PCB between the little PCB that plugs into the HDD and the motherboard. Turns out that the great amount of flex in the (crappy) plastic body of these laptops causes too much strain on the socket (opening and closing the screen) and eventually the connector breaks. I had to order a replacement PCB on Ali-express.
Ettienne -
Great guide, thanks a lot. One thing to note, I found it wasn't necessary to remove the whole hard drive controller just to replace the HD. I was able to just remove the audio port board and then slide the drive away from the controller.
Thanks again!
