Giriş
How to disassemble the laptop and replace the CMOS / BIOS Battery.
__________________ Video manual: __________________
Neye ihtiyacın var
Videoya Genel Bakış
The Keyboard is held by 5x locking clips.
Pick up a little the one side of the Keyboard and start opening the clips one by one.
Disconnect the Keyboard flex cable from the mother board and remove the KB.
Remove 3x Philips screws.
Disconnect the two small flex cables:
Power On button flex cable
Touch pad flex cable
Disconnect:
The Microphone cable
The LCD Display flex cable
Remove 3x Pillips screws.
Lift the board first from the right edge.
There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100
Use a sharp tool to remove the Battery.
CR2032 - button cell lithium battery rated at 3.0 volts.
Did you do it successfully?
7 farklı kişi bu kılavuzu tamamladı.
