Giriş
How to disassemble the laptop and replace the cooling / fan system.
_______________ Video manual: _______________
Videoya Genel Bakış
The Keyboard is held by 5x locking clips.
Pick up a little the one side of the Keyboard and start opening the clips one by one.
Disconnect the Keyboard flex cable from the mother board and remove the KB.
Remove 3x Philips screws.
Disconnect the two small flex cables:
Power On button flex cable
Touch pad flex cable
Disconnect:
The Microphone cable
The LCD Display flex cable
Remove 3x Pillips screws.
Lift the board first from the right edge.
There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100
Disconnect the Fan cable from the Motherboard.
Remove the screws (4x Phillips screws) that hold the cooling system to the Motherboard
CPU Cooling System - Cooling Heatsink and Fan.
