Giriş
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
Please SUBSCRIBE to my channel ツ
Videoya Genel Bakış
  1. Switch off the Laptop and remove the Battery. Unscrew the two Philips screws and remove the HDD / RAM Cover. Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard. Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  4. Remove the two Philips screws and separate the HDD from the caddy case.
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
Sonuç
3 başka kişi bu kılavuzu tamamladı.
ZFix
162.434 İtibar
304 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
280 Üyeler
783 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 17
Son 30 Gün: 99
Her zaman: 6,669
