Ana içeriğe geç
Asus X55C Motherboard Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Asus X55C Motherboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Switch off the laptop and remove the battery.
  2. Asus X55C Motherboard Replacement: adım 2, 3 resimden 1. Asus X55C Motherboard Replacement: adım 2, 3 resimden 2. Asus X55C Motherboard Replacement: adım 2, 3 resimden 3.
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Asus X55C Motherboard Replacement, Optical Drive: adım 3, 2 resimden 1. Asus X55C Motherboard Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the screw.
    • Pull out the SATA DVD Drive.
  4. Asus X55C Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Asus X55C Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  5. Asus X55C Motherboard Replacement: adım 5, 3 resimden 1. Asus X55C Motherboard Replacement: adım 5, 3 resimden 2. Asus X55C Motherboard Replacement: adım 5, 3 resimden 3.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  6. Asus X55C Motherboard Replacement: adım 6, 2 resimden 1. Asus X55C Motherboard Replacement: adım 6, 2 resimden 2.
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  7. Asus X55C Motherboard Replacement: adım 7, 3 resimden 1. Asus X55C Motherboard Replacement: adım 7, 3 resimden 2. Asus X55C Motherboard Replacement: adım 7, 3 resimden 3.
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  8. Asus X55C Motherboard Replacement: adım 8, 3 resimden 1. Asus X55C Motherboard Replacement: adım 8, 3 resimden 2. Asus X55C Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  9. Asus X55C Motherboard Replacement: adım 9, 2 resimden 1. Asus X55C Motherboard Replacement: adım 9, 2 resimden 2.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
192.056 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.525 adet Kılavuz yazıldı
Bir Yorum
Thank you very much for this information. My X55C laptop "fell" off the table with the power cord plugged in and broke the inside of the case that holds the receptacle. The power cord could no longer make good contact to charge the battery.
I was able to take the laptop apart, and get at the power cord. I have a temporary fix on the power cord, and a new case bottom on order.
ASUS quoted me about $300 to replace the case bottom if I sent it to them to replace the case. I found a case (used) on Ebay that was about $12 including S&H and will be here shortly. The only suggestion I have is to explain how the "ZIF" connectors for the Touchpad and Power Switch work. I almost destroyed them trying to get the Ribbon Cables out and back in.
Thanks again for a text and picture aid to fix this laptop model!!!!!!!!
schipka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 6,629
