Ana içeriğe geç
Asus X751L Battery Replacement
Neye ihtiyacın var
  1. Asus X751L Battery Replacement, Keyboard: adım 1, 1 resimden 1.
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: adım 3, 3 resimden 1. Asus X751L Battery Replacement: adım 3, 3 resimden 2. Asus X751L Battery Replacement: adım 3, 3 resimden 3.
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: adım 5, 2 resimden 1. Asus X751L Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: adım 6, 3 resimden 1. Asus X751L Battery Replacement: adım 6, 3 resimden 2. Asus X751L Battery Replacement: adım 6, 3 resimden 3.
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
John Enderton
576 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G2
4 Üyeler
5 adet Kılavuz yazıldı
6 Yorum
Very nice, thank you !
anh
barzamjavel - Yanıt
very nice, thank you !
Anh
barzamjavel - Yanıt
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Yanıt
Your instructions were easy to follow. Thank you!!!
theresa collet - Yanıt
very helpful
khan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 52
Her zaman: 12,781
