Ana içeriğe geç
Asus X751L Keyboard Replacement
Neye ihtiyacın var
  1. Asus X751L Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Keyboard Replacement: adım 3, 3 resimden 1. Asus X751L Keyboard Replacement: adım 3, 3 resimden 2. Asus X751L Keyboard Replacement: adım 3, 3 resimden 3.
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
John Enderton
576 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G2
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 3,136
