Ana içeriğe geç
Asus X751MA-DH01TQ Web Cam Replacement
Neye ihtiyacın var
  1. Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: adım 1, 2 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: adım 1, 2 resimden 2.
    • Turn the laptop upside down and locate the ten screws that hold the plate cover.
    • Remove all ten screws using a 00 Phillips head screwdriver.
  2. Asus X751MA-DH01TQ  Web Cam Replacement: adım 2, 2 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, pry the keyboard off of the base of the laptop.
    • Lift up and remove the keyboard.
  3. Asus X751MA-DH01TQ  Web Cam Replacement: adım 3, 3 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 3, 3 resimden 2. Asus X751MA-DH01TQ  Web Cam Replacement: adım 3, 3 resimden 3.
    • Remove eight 4.4 Phillips #00 screws attached to the hinge.
    • Hold the screen so it wont fall over.
  4. Asus X751MA-DH01TQ  Web Cam Replacement: adım 4, 3 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 4, 3 resimden 2. Asus X751MA-DH01TQ  Web Cam Replacement: adım 4, 3 resimden 3.
    • Remove the stickers from the bottom left and right corners of the screen.
    • Use a 00 Phillips head screw driver to remove the four screws.
  5. Asus X751MA-DH01TQ  Web Cam Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to take the screen apart.
  6. Asus X751MA-DH01TQ  Web Cam Replacement: adım 6, 2 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 6, 2 resimden 2.
    • Remove the two 4mm Phillips #00 screws attached to the webcam.
  7. Asus X751MA-DH01TQ  Web Cam Replacement: adım 7, 3 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 7, 3 resimden 2. Asus X751MA-DH01TQ  Web Cam Replacement: adım 7, 3 resimden 3.
    • Slowly pull up the webcam out of its slot, and begin to remove the wire.
  8. Asus X751MA-DH01TQ  Web Cam Replacement: adım 8, 2 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 8, 2 resimden 2.
    • Continue to unravel the wire and peel the webcam wire sticker off.
  9. Asus X751MA-DH01TQ  Web Cam Replacement: adım 9, 2 resimden 1. Asus X751MA-DH01TQ  Web Cam Replacement: adım 9, 2 resimden 2.
    • Once the sticker is peeled off pull the plug holding the webcam into the circuit board and the webcam is now disconnected.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 165
