Ana içeriğe geç
Asus X751MA-DH01TQ Battery Replacement
Neye ihtiyacın var
  1. Asus X751MA-DH01TQ Battery Replacement, Battery: adım 1, 2 resimden 1. Asus X751MA-DH01TQ Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down and locate the ten screws holding in the plate cover.
    • Remove all ten screws using a small Phillips head screwdriver.
  2. Asus X751MA-DH01TQ Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry open and separate the keyboard from the plate cover carefully.
    • The actual keyboard will detach not the back cover.
  3. Asus X751MA-DH01TQ Battery Replacement: adım 3, 2 resimden 1. Asus X751MA-DH01TQ Battery Replacement: adım 3, 2 resimden 2.
    • The battery contains wires connecting it to a circuit board. Slowly pull up and disconnect the wires from the board by pulling on the white tab.
  4. Asus X751MA-DH01TQ Battery Replacement: adım 4, 2 resimden 1. Asus X751MA-DH01TQ Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two 7mm screws holding the battery in place using a Phillips #00 screwdriver.
  5. Asus X751MA-DH01TQ Battery Replacement: adım 5, 1 resimden 1.
    • Carefully lift the battery up out of place.
Sonuç
Lindsey Romero
174 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,164
