Ana içeriğe geç
Asus X751MA-DH01TQ Screen Replacement
Neye ihtiyacın var
  1. Asus X751MA-DH01TQ Screen Replacement, Screen: adım 1, 2 resimden 1. Asus X751MA-DH01TQ Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Turn the laptop upside down.
    • Unscrew the 10 screws on the bottom of the laptop using a PH00 screwdriver bit.
  2. Asus X751MA-DH01TQ Screen Replacement: adım 2, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 2, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to detach and take off the keyboard.
  3. Asus X751MA-DH01TQ Screen Replacement: adım 3, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 3, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 3, 3 resimden 3.
    • Remove the eight 5.5 Phillips #00 screws located at the top right and left hand side of panel.
    • There are four screws on each side.
  4. Asus X751MA-DH01TQ Screen Replacement: adım 4, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 4, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 4, 3 resimden 3.
    • Remove the four 4mm Phillips #00 screws on the bottom left and right of the screen.
    • There are two screws on each side.
  5. Asus X751MA-DH01TQ Screen Replacement: adım 5, 1 resimden 1.
    • Insert the plastic opening tool on the side of the screen and slide it all the way around to open the screen up.
  6. Asus X751MA-DH01TQ Screen Replacement: adım 6, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 6, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 6, 3 resimden 3.
    • Remove the cords on the left and right side of the screen.
  7. Asus X751MA-DH01TQ Screen Replacement: adım 7, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 7, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 7, 3 resimden 3.
    • Remove the eight total screws (4 on each side) that are on the side of the white part on the back of the screen.
  8. Asus X751MA-DH01TQ Screen Replacement: adım 8, 3 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 8, 3 resimden 2. Asus X751MA-DH01TQ Screen Replacement: adım 8, 3 resimden 3.
    • Remove the two 4mm Phillips #00 screws on the top corners of the back of the screen.
    • Remove the metal bars that you have just unscrewed.
  9. Asus X751MA-DH01TQ Screen Replacement: adım 9, 2 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 9, 2 resimden 2.
    • Peel back the bronze sticker that is connecting the white border piece to the outside edge of the screen.
  10. Asus X751MA-DH01TQ Screen Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to pry open the white part away from the screen.
  11. Asus X751MA-DH01TQ Screen Replacement: adım 11, 2 resimden 1. Asus X751MA-DH01TQ Screen Replacement: adım 11, 2 resimden 2.
    • Pull the white part out and pull out the rest of the screen.
Sonuç
Collen Bleigh
198 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 470
