Ana içeriğe geç
Asus Z54C-JS31 Display Replacement
Neye ihtiyacın var
  1. Asus Z54C-JS31 Display Replacement, Battery: adım 1, 3 resimden 1. Asus Z54C-JS31 Display Replacement, Battery: adım 1, 3 resimden 2. Asus Z54C-JS31 Display Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Z54C-JS31 Display Replacement, Display: adım 2, 3 resimden 1. Asus Z54C-JS31 Display Replacement, Display: adım 2, 3 resimden 2. Asus Z54C-JS31 Display Replacement, Display: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open up the laptop and locate the two circular stickers at the bottom corners of the display.
    • Use a pair of tweezers to remove the two black stickers covering the screws.
    • Using a Philips #000 screwdriver, remove the two 9mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Z54C-JS31 Display Replacement: adım 3, 2 resimden 1. Asus Z54C-JS31 Display Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to pop off the plastic border around the display.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Z54C-JS31 Display Replacement: adım 4, 3 resimden 1. Asus Z54C-JS31 Display Replacement: adım 4, 3 resimden 2. Asus Z54C-JS31 Display Replacement: adım 4, 3 resimden 3.
    • Remove the two 9mm screws from the top corners of the display with a Phillips #000 screwdriver.
    • Carefully lift the display out and place the screen face down on the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Z54C-JS31 Display Replacement: adım 5, 1 resimden 1.
    • Disconnect the display cable connector attached to the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mark DeSimone
801 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G1
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 440
