Ana içeriğe geç
Asus Z54C-JS31 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Z54C-JS31 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Asus Z54C-JS31 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Asus Z54C-JS31 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: adım 2, 2 resimden 1. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: adım 2, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Hard Drive Replacement: adım 3, 2 resimden 1. Asus Z54C-JS31 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Hard Drive Replacement: adım 5, 3 resimden 1. Asus Z54C-JS31 Hard Drive Replacement: adım 5, 3 resimden 2. Asus Z54C-JS31 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
Sonuç
Mark DeSimone
801 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G1
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 129
