Ana içeriğe geç
Asus Z54C-JS31 Keyboard Replacement
Neye ihtiyacın var
  1. Asus Z54C-JS31 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Asus Z54C-JS31 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Asus Z54C-JS31 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Z54C-JS31 Keyboard Replacement, Keyboard: adım 2, 2 resimden 1. Asus Z54C-JS31 Keyboard Replacement, Keyboard: adım 2, 2 resimden 2.
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Z54C-JS31 Keyboard Replacement: adım 3, 3 resimden 1. Asus Z54C-JS31 Keyboard Replacement: adım 3, 3 resimden 2. Asus Z54C-JS31 Keyboard Replacement: adım 3, 3 resimden 3.
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mark DeSimone
801 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G1
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 439
