Ana içeriğe geç
Asus Z54C-JS31 Optical Disc Drive Replacement
Neye ihtiyacın var
  1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 2. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: adım 2, 2 resimden 1. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: adım 2, 2 resimden 2.
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Asus Z54C-JS31 Optical Disc Drive Replacement: adım 3, 3 resimden 1. Asus Z54C-JS31 Optical Disc Drive Replacement: adım 3, 3 resimden 2. Asus Z54C-JS31 Optical Disc Drive Replacement: adım 3, 3 resimden 3.
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  4. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: adım 4, 3 resimden 1. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: adım 4, 3 resimden 2. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: adım 4, 3 resimden 3.
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
Sonuç
Mark DeSimone
801 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G1
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 234
