Ana içeriğe geç
Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement
Neye ihtiyacın var
  1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement, Screen: adım 1, 2 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement, Screen: adım 1, 2 resimden 2.
    • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
    • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
    • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
  2. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 2, 2 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
  3. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 3, 3 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 3, 3 resimden 2. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 3, 3 resimden 3.
    • Place the computer on its back, facing up.
    • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
    • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
    • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
    • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
  4. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 4, 1 resimden 1.
    • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
    • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
  5. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 5, 3 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 5, 3 resimden 2. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 5, 3 resimden 3.
    • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
    • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
  6. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 6, 3 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 6, 3 resimden 2. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 6, 3 resimden 3.
    • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
    • Remove the cables from their terminals by slipping them away from their connectors.
    • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
  7. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement, Ethernet/LAN Port: adım 7, 2 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement, Ethernet/LAN Port: adım 7, 2 resimden 2.
    • Disconnect the ribbon cable from the side that has "MB" labeled on it by lifting up on the black locking flap and pulling the cable out of its terminal.
    • The black line on the ribbon cable marks the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
  8. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 8, 3 resimden 1. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 8, 3 resimden 2. Asus Zen AiO Pro Z240IC Ethernet/LAN Port Replacement: adım 8, 3 resimden 3.
    • Remove the four (4) 3.2 mm screws with a Phillips #1 screwdriver.
    • One screw is hidden under the ribbon cable.
    • Lift the board gently upwards to remove it from the base of the computer.
Sonuç
Sahil Sharma
348 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G1, Livingston Fall 2017 Cal Poly, Team S4-G1, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G1
5 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 1,087
