Ana içeriğe geç
Asus ZenBook Flip UX360C Motherboard Replacement
Neye ihtiyacın var
  1. Asus ZenBook Flip UX360C Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove all ten T5 screws on the back cover near the edges.
    • Remove two Phillips #1 screws located under the rubber feet near the screen.
  2. Asus ZenBook Flip UX360C Motherboard Replacement: adım 2, 3 resimden 1. Asus ZenBook Flip UX360C Motherboard Replacement: adım 2, 3 resimden 2. Asus ZenBook Flip UX360C Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a metal spudger to gently separate the keyboard from the computer case.
    • Do not completely remove the keyboard as there are two ribbon cables that connect the keyboard to the motherboard.
    • Lift the keyboard slightly, and use a plastic spudger to release the two ZIF connections to free each ribbon cable.
    • Remove the keyboard.
  3. Asus ZenBook Flip UX360C Motherboard Replacement: adım 3, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove all 5 mm screws.
  4. Asus ZenBook Flip UX360C Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool or nylon spudger to lift the monitor connections off of the main board.
  5. Asus ZenBook Flip UX360C Motherboard Replacement: adım 5, 2 resimden 1. Asus ZenBook Flip UX360C Motherboard Replacement: adım 5, 2 resimden 2.
    • Clip off the battery from the main board.
    • Use of a metal spudger can cause damage to the device or harm to the user, especially near the battery! Use an ESD safe tool for this step instead.
  6. Asus ZenBook Flip UX360C Motherboard Replacement: adım 6, 2 resimden 1. Asus ZenBook Flip UX360C Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the black foam above the screw on the I/O board.
    • Remove the 5 mm #1 Phillips head screw.
  7. Asus ZenBook Flip UX360C Motherboard Replacement: adım 7, 2 resimden 1. Asus ZenBook Flip UX360C Motherboard Replacement: adım 7, 2 resimden 2.
    • Pull the I/O board away from the chip to detach it.
    • Remove the I/O board and main board.
Sonuç
Jonathan Heintz
145 İtibar
1 Kılavuz yazıldı
Bir Yorum
where can i buy the motherboard?
Thevan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 3,047
