Ana içeriğe geç
Asus ZenBook Flip UX360C Screen Replacement
Neye ihtiyacın var
  1. Asus ZenBook Flip UX360C Screen Replacement, Screen: adım 1, 2 resimden 1. Asus ZenBook Flip UX360C Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Use a spudger to pry out the two rubber grommets from the front of the screen.
    • Remove the two 4mm Phillips Head #1 screws behind the grommets.
  2. Asus ZenBook Flip UX360C Screen Replacement: adım 2, 1 resimden 1.
    • Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
  3. Asus ZenBook Flip UX360C Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two 2 mm Phillips #00 camera screws.
    • Remove the 2 mm Phillips #0 upper circuit board screw.
    • Remove the 2 mm Phillips #0 lower circuit board screw.
  4. Asus ZenBook Flip UX360C Screen Replacement: adım 4, 2 resimden 1. Asus ZenBook Flip UX360C Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to unplug the two ribbon cables from the top half of the screen.
    • Detach the upper circuit board cable using the same method.
  5. Asus ZenBook Flip UX360C Screen Replacement: adım 5, 3 resimden 1. Asus ZenBook Flip UX360C Screen Replacement: adım 5, 3 resimden 2. Asus ZenBook Flip UX360C Screen Replacement: adım 5, 3 resimden 3.
    • On the bottom half of the screen remove the screen connection.
    • Disconnect the lower circuit board cable.
    • Separate the wiring from the casing, and remove the screen.
Sonuç
Kristopher Bright
397 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2022 IUPUI, Team 1-4, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 1,894
