Ana içeriğe geç
Asus ZenBook Flip UX360C Speaker Replacement
Neye ihtiyacın var
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: adım 1, 3 resimden 1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: adım 1, 3 resimden 2. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: adım 1, 3 resimden 3.
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: adım 2, 1 resimden 1.
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  3. Asus ZenBook Flip UX360C Speaker Replacement: adım 3, 1 resimden 1.
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  4. Asus ZenBook Flip UX360C Speaker Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to remove the keyboard panel.
  5. Asus ZenBook Flip UX360C Speaker Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  6. Asus ZenBook Flip UX360C Speaker Replacement: adım 6, 3 resimden 1. Asus ZenBook Flip UX360C Speaker Replacement: adım 6, 3 resimden 2. Asus ZenBook Flip UX360C Speaker Replacement: adım 6, 3 resimden 3.
    • Use nylon-tipped tweezeres to detach the battery connection.
  7. Asus ZenBook Flip UX360C Speaker Replacement: adım 7, 1 resimden 1.
    • Remove all ten Phillips #1 battery retaining screws.
  8. Asus ZenBook Flip UX360C Speaker Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
  9. Asus ZenBook Flip UX360C Speaker Replacement: adım 9, 3 resimden 1. Asus ZenBook Flip UX360C Speaker Replacement: adım 9, 3 resimden 2. Asus ZenBook Flip UX360C Speaker Replacement: adım 9, 3 resimden 3.
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
  10. Asus ZenBook Flip UX360C Speaker Replacement: adım 10, 2 resimden 1. Asus ZenBook Flip UX360C Speaker Replacement: adım 10, 2 resimden 2.
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
  11. Asus ZenBook Flip UX360C Speaker Replacement: adım 11, 3 resimden 1. Asus ZenBook Flip UX360C Speaker Replacement: adım 11, 3 resimden 2. Asus ZenBook Flip UX360C Speaker Replacement: adım 11, 3 resimden 3.
Sonuç
Kristopher Bright
397 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2022 IUPUI, Team 1-4, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 521
