Giriş
Removing the speaker module in the Asus ZenBook UX21e is relatively a simple process. By removing a few screws and prying off the housing, the speaker can be replaced in no time.
Neye ihtiyacın var
Unscrew the bottom frame cover using the T4 Torx screwdriver by removing the eight 2mm screws around the frame.
Unscrew the two 7 mm screws at the top of the frame using the T4 Torx screwdriver.
Unplug the speaker wire from the motherboard with blunt or angled tweezers.
