Ana içeriğe geç
Asus ZenBook UX303U Back Panel Replacement
Neye ihtiyacın var
  1. Asus ZenBook UX303U Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - Yanıt
  2. Asus ZenBook UX303U Back Panel Replacement: adım 2, 1 resimden 1.
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - Yanıt
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - Yanıt
  3. Asus ZenBook UX303U Back Panel Replacement: adım 3, 2 resimden 1. Asus ZenBook UX303U Back Panel Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Luis Perez
598 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G5
3 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Some models may utilize Phillips #00 screws, but mine (and many others based on what I’ve now read) utilize Torx T5 screws around the edges of the panel.
Nick Brennan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 5,237
