Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two round rubber feet at the hinge-edge of the laptop.
Remove the eleven 4 mm Phillips #00 screws from the back panel.
Using a plastic opening tool pry the back panel off of the laptop.
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Remove all seven 2 mm Phillips #00 screws from the battery.
Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
Lift the battery and speakers up and pull out to remove.
Disconnect the display cable from the motherboard with a plastic opening tool.
Remove the three 6mm Phillips #00 screws from the hinge.
Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
Lift the screen assembly hinge up and off of the motherboard fan.
Using tweezers, disconnect the cable connector from the motherboard fan.
Lift the fan up and off of the white pegs that secure it into place.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
