Ana içeriğe geç
Asus ZenBook UX303U Screen Assembly Replacement
Neye ihtiyacın var
    1. Asus ZenBook UX303U Screen Assembly Replacement, Back Panel: adım 1, 1 resimden 1.
      • Remove the two round rubber feet at the hinge-edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ZenBook UX303U Screen Assembly Replacement: adım 2, 1 resimden 1.
      • Remove the eleven 4 mm Phillips #00 screws from the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ZenBook UX303U Screen Assembly Replacement: adım 3, 2 resimden 1. Asus ZenBook UX303U Screen Assembly Replacement: adım 3, 2 resimden 2.
      • Using a plastic opening tool pry the back panel off of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus ZenBook UX303U Screen Assembly Replacement, Screen Assembly: adım 4, 2 resimden 1. Asus ZenBook UX303U Screen Assembly Replacement, Screen Assembly: adım 4, 2 resimden 2.
      • Remove cable connecting the screen assembly to the the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ZenBook UX303U Screen Assembly Replacement: adım 5, 3 resimden 1. Asus ZenBook UX303U Screen Assembly Replacement: adım 5, 3 resimden 2. Asus ZenBook UX303U Screen Assembly Replacement: adım 5, 3 resimden 3.
      • Remove the three 4mm Phillips #00 screws in the hinge to loosen the motherboard fan.
      • Lift the hinge up.
      • It is not necessary to remove the motherboard fan to replace the screen assembly.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ZenBook UX303U Screen Assembly Replacement: adım 6, 1 resimden 1.
      • Remove the three Phillips #00 screws securing the hinge to the IO board.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ZenBook UX303U Screen Assembly Replacement: adım 7, 2 resimden 1. Asus ZenBook UX303U Screen Assembly Replacement: adım 7, 2 resimden 2.
      • Remove the Wi-Fi card by pulling it straight out of its connector.
      FixBot'a Sor
      Yorum Ekle
    5. Asus ZenBook UX303U Screen Assembly Replacement: adım 8, 2 resimden 1. Asus ZenBook UX303U Screen Assembly Replacement: adım 8, 2 resimden 2.
      • Lift the entire lower assembly up and off of the hinges securing it into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Dean Anderson
701 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G5
3 Üyeler
9 adet Kılavuz yazıldı
7Kılavuz Yorumları
If anyone knows of a good, reliable source to buy a replacement screen assembly let me know, please. I have a 303U with the 1800 screen and I accidentally sat something heavy enough on top of the laptop to crack the screen on the right-third of the screen. I can’t use half of the touch screen and it’s fairly obvious depending on the color/brightness of the content I’m looking at. Would like to be able to replace this and these steps are pretty easy for me to follow so I’m confident I can have a newish looking laptop again if I can find a replacement screen.
chris.schroeder86 - Yanıt Paylaş
Hi ! Did you manage to find one? I’m trying to do the same thing :)
Adrien Rousseau - Yanıt Paylaş
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Yanıt Paylaş
It seems that the hinge assembly on one side is broken on my UX303U, on the screen side of the hinge. Do I need to replace the whole screen assembly? The laptop works perfectly otherwise.
Kobus - Yanıt Paylaş
Same here, asus ux303u screen side hinge is stuffed. But I think it may actually be the plastic screen cover itself where the hinge attaches, not just the hinge.
Dash OShea - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 65
Her zaman: 9,254
