Ana içeriğe geç
Giriş
Use this guide to replace the display in your Asus ZenFone 2 Laser 5" Model ZE550KL
  1. Remove the back cover.
    • Remove the back cover.
    • Disconnect the battery.
    • Remove the SIM card and the micro SD card.
  2. Unscrew the 15 screws
    • Unscrew the 15 screws
  3. Remove the plastic back with opening picks making sure not to break the clips that hold it in place Remove the plastic back with opening picks making sure not to break the clips that hold it in place
    • Remove the plastic back with opening picks making sure not to break the clips that hold it in place
  4. Disconnect the two flat cables by lifting the white bracket Unplug the camera Unplug the camera
    • Disconnect the two flat cables by lifting the white bracket
    • Unplug the camera
  5. With the help from a spudger, remove the rear speaker With the help from a spudger, remove the rear speaker
    • With the help from a spudger, remove the rear speaker
  6. Starting from the bottom lift the motherboard Starting from the bottom lift the motherboard Starting from the bottom lift the motherboard
    • Starting from the bottom lift the motherboard
  7. Mother board. Mother board. Mother board.
    • Mother board.
  8. Disconnect the touchscreen driver to remove the screen Disconnect the touchscreen driver to remove the screen Disconnect the touchscreen driver to remove the screen
    • Disconnect the touchscreen driver to remove the screen
  9. With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame
    • With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame
  10. Remove glue residues on the perimeter of the frame Re-adhere the display Re-adhere the display
    • Remove glue residues on the perimeter of the frame
    • Re-adhere the display
  11. apply the double-sided adhesive to the frame apply the double-sided adhesive to the frame apply the double-sided adhesive to the frame
    • apply the double-sided adhesive to the frame
  12. Replace or reposition the dust gasket of the front camera before installing the new screen Insert the new screen into position by passing the flat into the specific grooves Insert the new screen into position by passing the flat into the specific grooves
    • Replace or reposition the dust gasket of the front camera before installing the new screen
    • Insert the new screen into position by passing the flat into the specific grooves
  13. Refit the logic board Refit the logic board Refit the logic board
    • Refit the logic board
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
gwsLabs
457 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Just had my cracked LCD replaced. Everything was working fine before the replacement but after that, a third of a centimeter and all the subkeys (Back, Home, Recent keys) we rented working. The tech tried to checkout the fitting but it still didn't work. Had to install an assistive key app to be able to use the phone. He told me to go back on Thursday to replace the LCD with a different one cuz this last unit they had might be defective. Could it be a screen seating problem or an issue related to glue remnants or excess adhesive?
CJ Ogasawara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 4,258
