Ana içeriğe geç
Asus ZenFone 2 Vibration Motor Replacement
Neye ihtiyacın var
  1. Asus ZenFone 2 Vibration Motor Replacement, Removing the Back Cover: adım 1, 2 resimden 1. Asus ZenFone 2 Vibration Motor Replacement, Removing the Back Cover: adım 1, 2 resimden 2.
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Asus ZenFone 2 Vibration Motor Replacement, Remove the Inner Cover Screws: adım 2, 1 resimden 1.
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    The screw next to the camera with the sticker on (top middle on screen) was T4 not J00
    Matthew Hew - Yanıt
  3. Asus ZenFone 2 Vibration Motor Replacement, Remove the Inner Cover: adım 3, 2 resimden 1. Asus ZenFone 2 Vibration Motor Replacement, Remove the Inner Cover: adım 3, 2 resimden 2.
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Asus ZenFone 2 Vibration Motor Replacement, Remove the Speaker: adım 4, 1 resimden 1.
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
  5. Asus ZenFone 2 Vibration Motor Replacement, Vibration Motor: adım 5, 2 resimden 1. Asus ZenFone 2 Vibration Motor Replacement, Vibration Motor: adım 5, 2 resimden 2.
    • Use a plastic opening tool to remove the vibration motor.
    • Use a plastic opening tool to unplug the vibration motor at the indicated location.
    I need to replace MISSING vibration motor. What size is it? 8 mm? Thanks so much.
    LisaKK - Yanıt
Sonuç
Plug in the new vibration motor, and then reassemble your device by following the instructions for steps 1-4 in reverse order.
9 farklı kişi bu kılavuzu tamamladı.
Eduardo Nodarse
4.797 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G5
4 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
Will the phone still work without a vibration motor? The wires for the motor ripped and is stuck in the charging port, am I able to turn on the phone or wait until the parts been replaced?
Joerelyn - Yanıt
That's not a replacement... the final step is impossible => it will ripp the connector from the board.
I bought a replacement for the whole board, but it come without it, and i can"t put my old vibration motor on it... oh and the black square connector is present on the new part
Julien Mengelle - Yanıt
Can l power on the phone without vibration motor and simcard reader
Achhelal Pandey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 10,262
