Ana içeriğe geç
Asus ZenFone 5 Motherboard Replacement
Neye ihtiyacın var
  1. Asus ZenFone 5 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Asus ZenFone 5 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Asus ZenFone 5 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Motherboard Replacement: adım 2, 3 resimden 1. Asus ZenFone 5 Motherboard Replacement: adım 2, 3 resimden 2. Asus ZenFone 5 Motherboard Replacement: adım 2, 3 resimden 3.
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Motherboard Replacement: adım 3, 3 resimden 1. Asus ZenFone 5 Motherboard Replacement: adım 3, 3 resimden 2. Asus ZenFone 5 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Motherboard Replacement: adım 4, 2 resimden 1. Asus ZenFone 5 Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
  5. Asus ZenFone 5 Motherboard Replacement: adım 5, 2 resimden 1. Asus ZenFone 5 Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently use a spudger to remove the wired connections on the motherboard.
    • Disconnect both ribbon cables by popping up the locking tab of the zif connectors and pulling the cable out.
    • Pry up the black coaxial cable and it will pop off its connector on the motherboard.
    • Remove the two screws holding down the motherboard with a Phillips #00 screwdriver.
  6. Asus ZenFone 5 Motherboard Replacement: adım 6, 3 resimden 1. Asus ZenFone 5 Motherboard Replacement: adım 6, 3 resimden 2. Asus ZenFone 5 Motherboard Replacement: adım 6, 3 resimden 3.
    • Insert the pointed end of a spudger into the red rubber divot underneath the motherboard.
    • Gently pry the motherboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 1,979
