Ana içeriğe geç
Asus ZenWatch 2 Motherboard Replacement
Neye ihtiyacın var
    1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ZenWatch 2 Motherboard Replacement: adım 2, 2 resimden 1. Asus ZenWatch 2 Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove the two 1.8mm silver screws using the PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ZenWatch 2 Motherboard Replacement: adım 3, 2 resimden 1. Asus ZenWatch 2 Motherboard Replacement: adım 3, 2 resimden 2.
      • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ZenWatch 2 Motherboard Replacement: adım 4, 2 resimden 1. Asus ZenWatch 2 Motherboard Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Pull up on the motherboard using tweezers to detach it from the watch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew
335 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Spring 2017 USF Tampa, Team S1-G1, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G1
3 Üyeler
10 adet Kılavuz yazıldı
6Kılavuz Yorumları
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Yanıt Paylaş
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Yanıt Paylaş
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard - Yanıt Paylaş
Where can you purchase a replacement motherboard?
Tasha Kanahele - Yanıt Paylaş
My zenfone wach 2 all function not showing please help me
Akhtar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 3,133
