Ana içeriğe geç
Asus Zenbook UX303L Cooling Fan Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: adım 1, 1 resimden 1.
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: adım 2, 3 resimden 1. Asus Zenbook UX303L Cooling Fan Replacement: adım 2, 3 resimden 2. Asus Zenbook UX303L Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: adım 3, 2 resimden 1. Asus Zenbook UX303L Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: adım 4, 3 resimden 1. Asus Zenbook UX303L Cooling Fan Replacement: adım 4, 3 resimden 2. Asus Zenbook UX303L Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: adım 5, 3 resimden 1. Asus Zenbook UX303L Cooling Fan Replacement: adım 5, 3 resimden 2. Asus Zenbook UX303L Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: adım 6, 2 resimden 1. Asus Zenbook UX303L Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Gently lift and slide the cooling fan out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bianka Castaneda
469 İtibar
2 adet Kılavuz yazıldı
Ekip
3 Yorum
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Yanıt
I wish you guys had included the part number for the cooling fan.
mhyson - Yanıt
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 6,095
